daily System OS data usage
  • December 27, 2025
  • 4 replies
  • 65 views
A month ago, I bought a new dumb phone and   prepaid Koodoo a yearly sum for 400 minutes talk and 400 texts.  I do not have a data plan.
I have  roaming turned off. and mobile data turned off in my phone.
I just looked  at my data usage for the first time since getting the service a month ago. I noticed that every evening between 9 and 9:30pm there is an entry for .02Mb of data usage. Upon further investigation, I found that the System OS is responsible for this data usage. Is this normal? Why is it doing this?
  • December 28, 2025
If the plan doesn't have data, I wouldn't worry about it. System OS activities can be a lot of things. Given the small amount, it might be just daily handshake maintenance between your phone and the tower
Which phone is it, by the way?
  • December 28, 2025
You’re on prepaid so it’s nothing I’d worry about. You cannot be made to pay for extra data that your plan doesn't have or an add-on that you never bought. If it happens to use a tiny bit of data anyways that’s registered, then it is what it is for the OS and how it communicates with Koodo.
  • December 28, 2025
Thank you both for replies! Dinh, phone is a TCL 4058E.
  • December 28, 2025
Since it is a basic flip phone, I don't think you could do much in the settings. I would let it be and use the phone normally.
