Cant send or recieve mms
  • Jun 27, 2023 8:35 PM UTC
  • 3 replies
  • 172 views
Hi! Tried to reset network setting, telus specialist tried to solve it also for about 40 minutes, tried also different SMS apps to send. Nothing helps.
Your specialist told its on your side.
  • Organizer
  • Jun 27, 2023 8:36 PM UTC
oh, and this started after i switched  from Telus to Koodo.
Advices from this topic did not help
  • Organizer
  • Jun 28, 2023 4:02 AM UTC
is it such type of community where all questions with even author’s reply will be ignored?
  • Jun 28, 2023 6:37 AM UTC
We are all volunteers here and do not have fixed schedules. Depending on the question and its description, someone might reply to you early or not.
Regarding your issue, which phone are you using, and which troubleshooting steps have you performed?
As well, can you post your APN settings here? (hide/delete all personal information before posting pls) was it the same as Koodo APN? https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
