Call forwarding once I don't have my phone
  • Sep 12, 2023 10:13 PM UTC
  • 1 reply
  • 186 views
I lost my cellphone and waiting for an important phone, how can I do call forwarding remotely?
1 reply
  • Sep 13, 2023 12:29 AM UTC
https://www.koodomobile.com/en/help/call-forwarding
Those are your options unfortunately. If you cannot get a Sim swap done until you get another phone,  you can at least put your Sim card in someone else's phone to do it. If you cannot do this, then I suggest looking at voip options or giving the person you're waiting from a call to update your contact number.
