Block number that goes direct to voicemail
  • May 21, 2024 6:25 PM UTC
  • 1 reply
  • 356 views
Is there a way to stop a nuisance call that goes direct to voicemail? I suspect I may have blocked the caller, and now I have to clear a message from the same number on a daily basis. So frustrating.
1 reply
Sophia
  • May 21, 2024 6:31 PM UTC
If you are postpaid, you could enable call control. This blocks bots. However if your caller is a human, they would be able to bypass the block and leave a voicemail. You could disable voicemail by using the extended absence greeting, but that would mean no one could leave you a voicemail. Worst case you could change your number…
