battery draining fast after android 12 update
  • Nov 3, 2021 2:19 PM UTC
  • 383 views
After the android 12 update my battery is draining fast even with battery saver and adaptive battery on
Any fixes? Thanks
Best answer by Robert T
Give it a week for the OS to settle down and you should be able to get better battery life.
  • Nov 3, 2021 2:25 PM UTC
  • Nov 3, 2021 7:52 PM UTC
A restart wouldn't hurt either.
  • Nov 3, 2021 8:06 PM UTC
Re battery draining issue.
My phone is a pixel 3a  and before android 12 I was charging once a day, now it's three times a day.
I did do the restart and also shut down for a awile unfortunately nothing had helped.
Any other suggestions would be appreciated.
Thanks to the Koodo community for your help
  • Nov 3, 2021 8:24 PM UTC
It doesn't help you now, but I always recommend to not try to fix what isn't broken. Unless there is a phone issue, do not update.
I have been burnt many times when an update changes things for the worse and makes "improvements" that I don't want but I can no longer get rid off.
  • Nov 3, 2021 9:45 PM UTC
Does your Pixel 3a battery charge to 80% or 100%?
To help preserve battery health, your phone automatically limits charging to about 80% under certain conditions. The conditions and instructions on how to turn off battery optimization are listed in this link: Manage your Pixel phone battery see heading “Charging temporarily limited” (Pixel 3 & later).
