Bad Cellular Reception and Wifi Calling
  • Aug 1, 2023 7:36 AM UTC
  • 246 views
Hi! I have been Koodo for since the start of the year but I get a single bar and sometimes no reception in a basement unit where I got full signal with Fido. I have an S21 model number: SM-G991U1
I am also unable to get Wifi calling to work as whenever I enable it on my phone, there is a prompt to input my phone number to get a one-time access code. When I input my number it says “The number entered doesn’t match our records. Please re-enter your number.”
Any help would be appreciated.
  • Aug 1, 2023 12:59 PM UTC
Do you have good reception when you try enabling WiFi calling? You've gotta have it initially. If not, do you have VoLTE as an add-on in your self-serve?
  • Aug 1, 2023 2:17 PM UTC
Yes, I have tried enabling WiFi calling when I have good reception outside, however same issue with the one-time access code. When I input my number it says “The number entered doesn’t match our records. Please re-enter your number.”
I have volte enabled as an add-on my line through self serve
  • Aug 1, 2023 5:04 PM UTC
I think your model was incompatible with Koodo wifi calling. https://www.koodomobile.com/en/help/wifi-calling
The model should be a Canadian one not US model.
  • Aug 1, 2023 11:12 PM UTC
Well, it might not be supported officially however is it possible it still can be enabled? I think it may be just enabling the number in the "records" may enable it for me.
  • Aug 2, 2023 12:35 AM UTC
It should be enabled if the VoLTE add-on is already showing on your Self-Serve account.
