Apple ID seevices using data
  • Jan 19, 2023 9:34 PM UTC
  • 625 views
I've talked to apple support and they pointed me towards talking to the carrier to see what's wrong … Apple ID services is using a gig of data a day I have 20 gigs of data and it typically lasts around 2 weeks (14 gigs of it are Apple ID)! They wouldn't tell me any setting or anything or do anything on their end I've deep dived the internet to see if I could shut anything else off and nothing I've tried has worked! Any ideas or clues to what it may be?
  • Jan 19, 2023 10:46 PM UTC
Did you mean “system services” of an Iphone? If so, you can go to settings » cellular » system services to see fhe detail (imessage, documents, maps...). From there you migjt have a better idea of what happened. Also, while you are at “cellular”, scroll down and select "settings”.
  • Jan 20, 2023 12:06 AM UTC
In system services I'm really only worried about the Apple ID services one as its 1.8 gigs in less than 2 days
  • Jan 20, 2023 2:07 AM UTC
I trust you are actually resetting your data usage on your monthly renewal date as it is not automatic?
  • Jan 20, 2023 2:09 AM UTC
Yes I reset it yesterday morning to see how much data it was actually using
  • Jan 20, 2023 2:30 AM UTC
From what I searched online, this seems to be a known issue with Apple iOS. There were many reports on Apple community. Some asked other to contact Apple to see what happened.
I am using an iPhone myself. I haven't reset my data usage for months and apple id service only consumed 142mb. It is no where near your phone.
As of now, I would recommend you reset network settings first. The go to apple icloud in your phone, Sign out, restart the phone and sign back in again.
  • Jan 20, 2023 2:54 AM UTC
I'll try that, test it for a day and see what happens thank you :) I'll message on this again if it doesn't work
