5G slower than 4G/LTE
  • Aug 29, 2023 10:05 PM UTC
  • 2 replies
  • 490 views
I just swapped my plan to a 5G plan on a pixel 7.
My speeds using 5G are measuring slower than if I force my phone to use 4G.
Any advice?
  • Aug 30, 2023 12:42 AM UTC
Well, it depends on if you are close to a 5G tower or not. If you were far away from a 5G tower but there was a LTE tower nearby, that LTE tower might provide better connection and speed.
  • Aug 30, 2023 1:57 PM UTC
I’m downtown Calgary, according to the coverage map I should be right in the middle of the 5G coverage area.
