wifi calling not working
  • March 21, 2026
  • 22 replies
  • 90 views
I cannot get wifi calling anymore at work. I use to with my iPhone 8 and then it stopped working and now I have an iPhone 16e and still not working. Some people have mentioned on here about VoLTE add on in self serve but I do not see one. This has been ongoing for months. Could someone help?
  • Advisor
  • March 21, 2026
Any Rep’s on here that can help with this?
  • March 21, 2026
To confirm, is it only at your work that wifi calling does not work or does it work for you in other locations?
Have you tried any troubleshooting already while at work, like resetting your network settings or restarting the device?
  • Advisor
  • March 21, 2026
Hello, thanks for reaching out. Yes I’ve reset airplane mode, network settings, toggled on and off everything that’s mentioned. And powered off my phone 100’s of times. Been ongoing for months. It worked for years then all of a sudden it didn’t. I thought it was my old iPhone 8 but still doing it with my new 16e. I noticed some people had comments similar to mine and someone replied that VoLTE was now added to there add on’s under self serve. But I do not see it in mine.
  • March 21, 2026
Hmm ok. In that case I will flag a rep to check out your account as you have already tried some troubleshooting and VoLTE does not appear in your plan add ons.
Please make sure you're logged into the community using your self serve credentials and they should be able to take a look. The response times can vary, but a rep will respond here as I have. 🙂
  • Advisor
  • March 21, 2026
Thank you for any help you can give. Much appreciated
  • March 21, 2026
Hi ​@Icarium13
We can look into it for you!
Can you please confirm the last 2 digits of the phone number in question?
  • Advisor
  • March 21, 2026
42
  • March 21, 2026
Thank you for confirming ​@Icarium13
Can you please restart your phone and then try again? Please let us know if it works!
  • Advisor
  • March 21, 2026
Still not working
  • March 21, 2026
@Icarium13
Just to double check, you are not seeing the option to activate it on your phone or you are getting an error when you try to activate it?
  • Advisor
  • March 21, 2026
Where would I see the option to activate?
  • March 21, 2026
@Icarium13
If you go to Settings > Cellular on your phone, do you see the option to toggle Wi-Fi Calling on?
  • Advisor
  • March 21, 2026
Yes it is on. And it gave me option to enable.
  • March 21, 2026
Got it!
So it is on, but it is still not working?
  • Advisor
  • March 21, 2026
Yes, still not working
  • Advisor
  • March 21, 2026
What other things in to be on under cellular, etc. on the phone? And does it matter about 5G auto, 5G, or LTE?
  • Advisor
  • March 21, 2026
And should I turn wifi assist off?
  • March 21, 2026
Hi ​@Icarium13
We have just sent you a PM so we can confirm some more details, please check your communit inbox when you get the chance.
  • March 21, 2026
I recommend you leave the settings at 5G Auto.
Koodo WiFi calling only turn on when the cellular signal is weak and the WiFi network is compatible. How many bar of signal you have on your phone? I assume you are a postpaid customer?
  • Advisor
  • March 21, 2026
Hello, I pay a monthly bill and I have zero cellular at the moment due to being in the middle of the Atlantic Ocean. I have all wifi bars.
i notice under general , and under about, it says network not available under physical sim. Would that be an issue?
  • March 21, 2026
Oh, Koodo WiFi calling doesn’t work overseas though. It only works within Canada.
Also, from time to time, it might need access to cellular signal to ensure network security.
  • Advisor
  • March 21, 2026
Thank you for your help. I will try it again when I get home from work in 21 days. Cheers
