What is the impact of Phone Number Change for the existing Koodo Plan?
  • Aug 31, 2022 6:36 PM UTC
  • 301 views
I want to change my Koodo phone number due to relocation from one province to another. I was wondering if it impacts my existing Koodo plans. Is there any impact on my monthly bill due to that change?
Unfortunately, I haven’t found any terms and conditions details for that Koodo phone number change process.
Philosoraptor
If your current plan isn't a region-specific plan, there should be no change. If you've moved to a region that has never offered your plan, you'll have to choose from a plan currently offered in your new region.
  • Aug 31, 2022 7:05 PM UTC
I never heard about that region specific plan on my plan. How could we find out that? My plan include nationwide unlimited calls and text messages. Does it mean it’s not a region-specific plan?
Changing the phone number through self-service is a bit straight forward. But I’m worried about the post impact because there is always some catch 😐
Philosoraptor
Typically Quebec and Saskatchewan have had lower-prices than the rest. If you're moving away from these, then you'll likely have to change plans.
  • Aug 31, 2022 7:12 PM UTC
If it’s the case then I’m good 😀 I’m neither moving away from QC/SK nor moving in to QC/SK 😀
Thanks!
Thanks!
  • Sep 1, 2022 2:03 PM UTC
Only changes you should see is taxes and fees changes. It may amount to a dollar difference or something like that .
