Usage details from April
  • Jul 5, 2022 1:57 PM UTC
  • 1 reply
  • 133 views
Hello, is there a way to see messaging usage from the beginning of April
1 reply
Allan M
  • Jul 5, 2022 6:38 PM UTC
You should be able to see the past two months within your self serve account (depending on your billing cycle this may or may not include April). Past that, the most you can get would be the number of texts that were sent which is displayed on your ebills.
