Unable to send or recieve texts after switching to Koodo
  • Apr 11, 2024 1:27 AM UTC
  • 7 replies
  • 469 views
I just switched from Rogers to Koodo today. Left the kiosk thinking everything was good to go only to find out I cannot send or recieve text messages. I have done all the steps recommended and still not working. I can make and recieve phone calls and use other messaging apps. I also have not recieved any sort of welcoming email. I cannot register my account as I can get the code they text to set it up.
Help
  • Apr 11, 2024 3:21 AM UTC
It seems the port wasn't completed. Did you got a help from a rep to do it or you did yourself in selfserve? Have you tried to check the statu of the port in your selfserve?
  • Apr 11, 2024 3:47 AM UTC
I got a rep at the telus/koodo store to do it. I can't set up my self-serve because I need the code they text to you to set it up and I am unable to recieve texts.
  • Apr 11, 2024 3:51 AM UTC
You need Koodo selfserve activation email to create a selfserve account, there was no need for the text to your number.
  • Apr 11, 2024 3:54 AM UTC
Well I received no email and when I follow the instructions on the paper the rep gave me to register for my self-serve it asks for the phone number to send the code to, to continue the process.
  • Apr 11, 2024 4:11 AM UTC
Eh, are you a prepaid customer? If you are a postpaid customer you should have received a lot of information to your email as of now. Anyway, i recommend you schedule a call back from Koodo with Koodo assist so a rep help you to finish the port. Www.koodo.com/chat
  • Apr 11, 2024 4:16 AM UTC
I am a prepaid customer. I did schedule a call back for tomorrow. I was just hoping I could fix it before then...
Thank you for your help
  • Apr 11, 2024 6:39 AM UTC
Porting issue would need a rep over the phone to validate and assist though. It is a customer security issue that they have to do that
