unable to login to my account
  • November 26, 2025
  • 7 replies
  • 67 views
I have try multiple attempts to login to my account.  Keep saying I have incorrect user name or password.  Tried reset password but stil unable to login.
  • November 26, 2025
Are you a Postpaid or prepaid customer? As well, are you currently residing in Canada or using VPN?
  • November 26, 2025
If you recently updated or reconfirmed info on your account, you might need to use your email address (not just a username) to log in now.
If you haven’t tried this yet, enter your full email where it asks for username and see if that works.
More info: https://www.koodomobile.com/en/help/article-categories/login-and-profile
  • Advisor
  • November 26, 2025
i am a postpaid customer, within canada and not using VPN
  • November 26, 2025
Can you try to use the incognito mode and use a different web browsers to see if that can help. If you can Use Koodo cell network to log in
There are as well an ongoing glitch with self-service affecting certain customer. Can you share the details of your device?
  • Advisor
  • November 26, 2025
i always used my email address to login.  I have tried using a device just now and work, so not sure what happened.
  • Advisor
  • November 26, 2025
Can you try to use the incognito mode and use a different web browsers to see if that can help. If you can Use Koodo cell network to log in to see if that can help
i tried incongito mode on the same device and still didn’t work.  I tried to login from a different laptop and was finally able to get in.  Thanks
  • November 26, 2025
, that happened to me and several other with older devices as well. Koodo currently is looking into it. Hopefully they can fix it soon
