transfer phone number
  • February 25, 2026
  • 57 views
I have tried multiple times to enter , number, account info and imei number exactly and it keeps saying i have not entered correct number
  • February 25, 2026
Is it possible that you may have port protection enabled on your account with your existing service provider? Have you followed up with them?
  • February 25, 2026
Can you elaborate on which number it is saying is incorrect? Does it specify?
In addition you should only have to type in either the account number or the imei, not both. I suggest you just enter the account number from your previous provider and leave out the imei. See if this works.
  • February 26, 2026
Not sure what port protection is but i will check with carrier.
i have tried account # and imei number multiple times and double checked that all info correct. Under the account#/imei field it says something like “make sure you enter the correct number”. I can get no further than that.
thanks!
  • February 26, 2026
Can i call and talk to a human?
  • February 26, 2026
Hi ​@climbinglogger, we’ve sent you a private message to confirm some details. Please check your community inbox when you get the chance, thank you!
