To avoid roaming charge
  • Jul 12, 2023 5:28 PM UTC
  • 2 replies
  • 328 views
I am going to go abroad for vacation.
If I turn off data and then turn on Airplane mode and WIFI at the same time then I won’t be worried about the roaming fee, am I right? Also I can use the apps in my phone without being charged including sending back text message or (RCS message)?
Sophia
  • Jul 12, 2023 6:07 PM UTC
Correct, though I’m not sure if you can send or receive RCS messages in airplane mode. If not, you might want to consider something like WhatsApp or another chat messenger that uses WiFi, not cellular data. That way you could even remove your Canadian SIM during your travels and use a local one instead, to have Internet on the go.
  • Jul 13, 2023 2:39 PM UTC
To clarify even Sending back text messages will trigger easy roam.
If you have your RCS settings set to send as SMS if RCS fails, then any outgoing text messages that go through will trigger easy roam.
I would personally turn off data and data roaming settings in your phone.  Then I would turn on airplane mode and turn on wifi and then take out my sim card.  If for some reason I needed an incoming text (2FA, etc) I would then pop in my sim card.
