SIM not working
  • Sep 27, 2021 4:46 PM UTC
  • 13 replies
  • 1208 views
Hi all,
We've recently migrated from Virgin to Koodo, and someone else (not me) went to the kiosk to buy the SIM cards. The phones keep saying that SIM card is not supported, and there is no technical assistance number for new customers to call, can someone assist with this issue?
Thanks!!
Best answer by Dinh
Which iOS is the phone on? Was it ios14? Or still ios 13?  Apple mentioned if you are on 13 or earlier, you might have to reset the device to its factory settings or restore its from a backup to unlock the iPhone. https://support.apple.com/en-us/HT201328 I think if you still see the message, the phone might not been unlocked properly. Bell and virgin mobile are from the same company though. If possible, I recommend you test out with sim from another carrier besides Koodo and see if the problem was from the phone or the SIM.
  • Sep 27, 2021 4:58 PM UTC
Was the porting process done at the kiosk as well?
  • Organizer
  • Sep 27, 2021 7:06 PM UTC
yes, I think 1 was, and there is another that needs to be, per the kiosk guy. My previous Virgin SIM will work in the phones, so it appears to be an issue with the SIM, but I’m not sure what
  • Sep 28, 2021 12:21 AM UTC
If you saw the message “sim card not supported” when you put the Koodo SIM into the phone, your phone was likely locked to Virgin Mobile. You would have to contact Virgin and ask them to unlock for you. It should be free of charge by regulations.
  • Organizer
  • Sep 28, 2021 12:25 AM UTC
Hi Dinh,
Thank you for your response, it was initially locked to Bell, who have unlocked it, and the message is the same on the other phone, and I have not inserted the Virgin SIM into that one, so it’s not the issue with Bell or Virgin, there’s an issue with Koodo.
  • Sep 28, 2021 12:29 AM UTC
Hi Dinh,
Not really sure if you checked the unlocked status yet. Was it an iPhone? If it was, Can you go to settings » about » carrier lock. What did it say there?
  • Organizer
  • Sep 28, 2021 12:58 AM UTC
Hi Dinh,
Thanks again for responding, but I can’t get to the settings at all. The farthest I can get is choosing the wifi, from there the phone informs me that the SIM is not supported. Any other tricks I could try?
  • Sep 28, 2021 1:20 AM UTC
Hi Dinh,
Which phone was it?
  • Organizer
iPhone 6
  • Sep 28, 2021 1:57 AM UTC
  • Organizer
  • Sep 28, 2021 3:17 PM UTC
Hi Dinh,
You’re so helpful, and your suggestion yesterday led me to rethinking the game plan. I hooked the phones up to iTunes, and had iTunes update from the original os 9.2.1 to 12.5.5. I hooked them up again to iTunes today and got this message, so I’m really not sure where to go from here, so any other ideas are most welcome!!
  • Sep 29, 2021 3:44 AM UTC
Hi Dinh,
Is your iPhone locked? That may be the reason why the error message is popping up on the screen. https://support.apple.com/en-ca/HT201328
You have to contact Bell or Virgin Mobile and ask them to unlock your device. They will need to reach out to Apple directly to make the request before you can properly use the device with your Koodo SIM card.
  • Sep 29, 2021 4:19 AM UTC
Hi Dinh,
Are you sure it was unlocked? Looks to me that it’s not unlocked.
  • Organizer
  • Oct 14, 2021 8:10 PM UTC
Hi everyone!!
So it did eventually get unlocked, so thank so much Dinh!! It was an issue that Bell had, I think there might be a superficial unlock and a deeper unlock, and that had to be done as well, so for anyone else with this issue, stay on the phone with the initial carrier, and ask to speak to the technical department yourself, rather than just rely on the word of customer service!!
