Shouldn’t Koodo make sure their software works
  • May 11, 2024 10:50 PM UTC
  • 2 replies
  • 61 views
Trying to take 2 phones off seasonal plans. Asks me to take off seasonal hold. Do that. Bunch of plans show up so I can select one . Do that then it just shows 3 dots fading in and out. Both accounts do that. Really frustrating to have a self serve system that makes it very difficult to contact someone to fix their software problem   Don’t know what to do is there a phone number or email where I can call someone to fix their problem.
  • May 11, 2024 11:01 PM UTC
I am using a iPad Pro version 3. Just got it to work on iPad generation 1.
Sophia
  • May 11, 2024 11:03 PM UTC
Ok, so you don't need help any longer? Wasn't quite clear from your post 😊
