Short code sms
  • Mar 5, 2024 8:15 PM UTC
  • 287 views
Hi everyone,
Most customers on facebook and any meta sites experinced a wide outage of the apps. I have been unable to log into anything since 9AM EST. That being said, I  have requested multipe codes to reset accounts to log back in,knowing my password and such. Does anyone else not receive  short code SMS  to their phones or is this just an isolated incident on my part?
Thanks!
  • Mar 5, 2024 8:24 PM UTC
Hi @Twatton
Are you having issues also with receiving regular text messages or it’s just the short codes that you do not receive messages from?
  • Mar 5, 2024 8:25 PM UTC
It’s just the short codes that I do not receive or I receive them days after
  • Mar 5, 2024 9:02 PM UTC
The Meta outage should be resolved by now.  Are you having issues with Meta short codes or any short codes?  Do you have examples of which short codes are going you issues?  Are there any that work properly
  • Mar 5, 2024 9:04 PM UTC
It is as far as I’m aware. A close friend of mine is experiencing the same issue. It’s just with Meta short codes. This happened a few weeks ago as well and I was still getting nothing.
  • Mar 5, 2024 9:13 PM UTC
If it is just happening with meta short codes, it sounds like it is a Meta issue.
Are you sure the Meta short code is going to the correct phone number?  COuld it be going to an alternate or old phone number?
  • Mar 5, 2024 9:15 PM UTC
That’s what I’m beginning to think the issue is since it’s just a meta issue. It’s going to the correct number but I’m just not receiving it at all. Well, at least I know it’s probably not a service provider issue
