Change sim card with email verification does not work.
I get stuck on a loading screen
Did you receive the code to your email? As well, are you currently residing in Canada?
I get the code in email and enter it into the self serve, it then gets stuck on a loading screen.
I reside in canada
I reside in canada
I saw a similar report of issue with code to the email. Were you able to receive the code to your SIM card instead?
I reside in canada
The SIM card is currently not working hence the swap I am trying to do.
What had happened was I had the SIM card converted to a e-sim but then deleted the e-sim at some point rendering the physical SIM useless.
I reside in canada
I saw one similar case with eSIM in the forum. If self-serve didn’t work you would have to schedule a call back to another number that you have access to or visit a Koodo store and ask a rep to assist unfortunately.
Login to the community
