Self Serve Account
  • Mar 29, 2023 1:59 AM UTC
  • 282 views
Hi,
I just signed up for 2 lines with koodo for my brother and I and it’s under the same account,  I was wondering will he have to share the same account as me to check his usage or can he have a separate account, if so how can I make an account for him if I only have one account number.
 Thank you.
Best answer by Dinh
If you signed up for him under your name, Koodo considered you as the account owner and there wasn't a way to separate lines in the same account to another one. So you and your brother would have to share username and password if you would like him to check his usage himself.
  • Mar 29, 2023 2:57 AM UTC
  • Mar 29, 2023 6:03 AM UTC
thank you so much for the info!
  • Member
  • Apr 10, 2023 3:41 AM UTC
Unable to complete the registration when opening Self Serve account, same error keeps popping up
  • Apr 10, 2023 7:33 AM UTC
@zakiiiii : i recommend you create another topic of your own. The customer in this topic didn't mention any error and was likely having different issue.
  • Apr 10, 2023 1:42 PM UTC
Make sure you mention what the error is so we can help you out
