Remove VoLTE
  • Nov 18, 2021 9:46 AM UTC
  • 21 replies
  • 1213 views
Does anybody actually know how to turn off VoLTE? It’s not an option I can toggle on my phone, so I found an option in my Self Serve Add Ons. I removed it, got the confirmation, and nothing happens.  I literally have to turn off LTE right now, since my apartment buzzer does not work with VoLTE calls, specifically on Telus/Koodo. Apparently works with all the other providers though. Did the whole song and dance with CS and they weren’t very helpful.
Best answer by rikkster
It seems you’re not the only one with a missing VoLTE toggle switch. Reports from the Samsung Community confirm that after the One UI 3.0 update, the VoLTE toggle switch has disappeared. There is mention of an app that can access hidden network features which may allow you to turn off VoLTE. Reviews on the app vary, but it may be worth a try.
VoLTE missing after One UI 3.0 Update
Samsung Band Selection app
  • Nov 18, 2021 2:17 PM UTC
Which phone are you using?. You can remove the volte option by remove the “volte access” add on in selfserve.
  • Nov 19, 2021 5:36 AM UTC
What phone do You have?
You should have a setting for VoLTE
See the instructions here
https://www.koodomobile.com/help/volte
I assume you tested your phone that when LTE is turn off completely, that your apartment buzzer works?
  • Coach
  • Nov 19, 2021 6:46 AM UTC
Samsung Note 20,
I’ve checked, there’s not an option to turn off VoLTE on my phone. Not sure if that’s a phone thing or a SIM thing.
  • Coach
  • Nov 19, 2021 6:48 AM UTC
Yeah if I only select WCDMA/GSM then the buzzer works, if I have LTE/WCDMA/GSM selected then it doesn’t work. There’s no VoLTE toggle or switch or option in my settings.
  • Nov 19, 2021 7:20 AM UTC
Samsung Note 20,
I think I asked you to check Koodo selfserve account though. I didn't ask you to check the phone.
  • Coach
  • Nov 19, 2021 7:21 AM UTC
Samsung Note 20,
I did that first, which is why I made this post. It confirms the cancellation of the add-on, then I wait 15 min to let it update, and it’s right back there again. Koodo CSR’s are pretty clueless when I called in to ask about it
  • Coach
  • Nov 19, 2021 7:23 AM UTC
https://i.imgur.com/O4Dz5bu.png
https://i.imgur.com/TBhV0ai.png
https://i.imgur.com/XpkGDf1.png
Just did it again to get some screenshots. I did this last night about 3 or 4 times, tonight still there, despite me removing it over 24 hours ago
  • Coach
  • Nov 19, 2021 7:42 AM UTC
Still on my account, 20 min later.
  • Nov 19, 2021 8:44 AM UTC
Let me flag a rep. it could be an error in selfserve preventing this.
  • Coach
  • Nov 19, 2021 9:53 AM UTC
ooh that would be nice, thanks!
  • Nov 19, 2021 12:40 PM UTC
Have you tried the following steps?
  1. Swipe down from the top of the screen with one finger.
  2. Tap the Settings icon.
  3. Tap Connections.
  4. Tap Mobile Networks.
  5. Tap the status switch beside VoLTE Calls to toggle it on and off.
  • Nov 19, 2021 1:16 PM UTC
Hi @link2110
Please try the steps that @MilkyWay posted in the previous reply and see how it goes.
We’ve sent you a PM as well with more details and steps to follow in case you do not find the toggle.
  • Nov 19, 2021 6:43 PM UTC
That is so weird.
Is this a koodo purchased phone?
I have the Note 20 Ultra and see this.
Also I don't understand why VoLTE would cause your buzzer to not receive calls. Do others calling you work with LTE on?
Maybe try to reset your network settings?
  • Coach
  • Nov 20, 2021 8:34 AM UTC
Hi @link2110
I don’t have the status switch.  I’ve tried resetting network settings already, which also doesn’t work.
  • Coach
  • Nov 20, 2021 8:36 AM UTC
That is so weird.
It is a Koodo purchased phone, no clue why I don’t seem to have the option.
As for why the buzzer doesn’t work, no clue either, but I get the call, and when I push the number to let somebody in, the buzzer system doesn’t seem to pick up on that keytone and it just hangs up, and the door doesn’t open.  My building manager confirmed that this issue is only on Telus/Koodo, and not Rogers/Shaw/Bell etc
  • Nov 20, 2021 4:35 PM UTC
  • Coach
  • Nov 20, 2021 6:30 PM UTC
Wow, thank you so much! It worked!
  • Ambassador
  • Dec 2, 2021 5:51 PM UTC
I’m missing the VoLTE switch on my Samsung Galaxy S20 fe 5g as well.
  • Dec 2, 2021 6:35 PM UTC
Did the app work?
  • Ambassador
  • Dec 2, 2021 7:14 PM UTC
It did give me access to VoLTE switch, but I’m still not able to get my name to display on outgoing calls.
  • Dec 2, 2021 7:31 PM UTC
Head back to your original post. I’ve provided an answer there.
