Prepaid Self Serve
  • May 17, 2023 4:54 PM UTC
  • 2 replies
  • 228 views
I have to say, after all of my complaints about logging into my Prepaid self serve, that the last couple of times it opens in about 20-30 seconds instead of the 5-8 minutes it took previously. So kudos to the Koodo techies that finally got things together to correct the problem.
BobTheElectrician
Sadly, still can’t log in with correct credentials unless the brower is freshly started. Same data entered after restart works like a charm… exactly once.
  • Rockstar
  • May 17, 2023 8:14 PM UTC
You are right Bob, I thought it was just me. The first attempt to sign in always fails. Second time it connects like it should.
