Phone Number Change
I changed my phone number online through the self serve portal and my account shows the new number, however my phone still shows the old number. It’s been 2 hours since the change went through online and I have restarted my phone 3 times as well as powered it off for 10 minutes and powered back on and my phone is still showing the old number.
Did this help you find an answer to your question?
  • 17351 replies
  • March 15, 2025
Hi
Where did it show your old number? Was it in contact or settings? As well, which phone are you using? if you are using other messaging service like iMessage or RCS, have you tried to turn them off and reenable again?
  • 1 reply
  • March 16, 2025
It all works now,  disregard, thank you.
