my profile / self serve not loading
  • May 9, 2022 5:02 PM UTC
  • 9 replies
  • 1920 views
When I try and pull up mobile services it just gives me a blank screen
  • May 9, 2022 6:25 PM UTC
When you first login does the page open properly? Hoe about when you go to the usage page?
  • May 9, 2022 6:50 PM UTC
The page after logging in loads up. The usage page gives me the same blank screen. Same with everything else under self serve
  • May 9, 2022 8:17 PM UTC
Try clearing your browser's cache or trying another browser to see if that fixes things
  • May 9, 2022 9:22 PM UTC
Yeah I’ve done that and tried it on 3 different browsers, would it be because my account is too new?
  • May 9, 2022 9:28 PM UTC
I will also add that even when I go to the “shop” after I am logged in it prompts me to select an account and from there I can’t do anything
  • May 10, 2022 2:22 PM UTC
Let me flag a rep for you
Boa_Guy Koodo
@Edr96 Hi there! The reason you are not able to access your Koodo Self-Serve, its because you don’t actually have an active account. The migration from TELUS wasn’t completed yet. Once the migration and port is completed, you will have access to your Self-serve.
Hope this helped.
Cheers,
  • May 10, 2022 3:17 PM UTC
I was told that process had failed and I had to wait for a sim card to do it manually. If I can’t access your website I how will I be able to do this when I receive the SIM card ?
Boa_Guy Koodo
@Edr96 , No worries! When you receive the SIM, you can call in and they will complete the activation of the SIM and your account at the same time since it's a migration from TELUS.
