Move over from Telus
  • Jun 21, 2022 10:00 PM UTC
  • 7 replies
  • 326 views
Phillip Mastroianni
Hello
I have a family plan at telus, but would like to move to Kodoo.  What is the best way to do this?  Purchase a 4 separate SIMS (accounts) or create one account with 4 SIMS?
Thanks,
  • Jun 21, 2022 10:51 PM UTC
Depends. Do you want to be paying all 4 accounts under 1 bill or you want 4 different bills?
  • Jun 21, 2022 10:57 PM UTC
Also will the other lines likely need to be separated anytime soon?
A transfer of ownership costs $50
https://www.koodomobile.com/help/transfer-of-ownership-town
Phillip Mastroianni
OK, that is helpful.
If I got the separate SIM card, can I buy sims in the name of each person (ie wife, kids, etc) and use my credit card?
Thanks,
Sophia
  • Jun 21, 2022 11:33 PM UTC
That depends. Using your credit card is not the problem, but the account holder will be the one who shows their ID and sets up the account.
If they are the age of majority, each of them will need to pass a credit check and show ID if you want the account under their own name… because if you are the one who sets up all those lines, they will all be under your name.
Edit: that is assuming you are talking about postpaid plans. Prepaid plans can be under anyone’s name and don’t need a credit check.
Phillip Mastroianni
But for myself I don’t want an account, work will cover it.
How do I go about setting up 4 accounts under my name?
  • Jun 21, 2022 11:55 PM UTC
If you want to put all of your accounts under one name, you are better off going to your nearest Koodo store to get that sorted out. Note there is a $50 connection fee for each line that is activated in-store.
  • Jun 23, 2022 2:31 AM UTC
You likely won't be able to set up 4 account under your name. It will trigger a fraud response which will be more of a headache if they freeze your accounts and lines while they investigate
