Is it possible to portal an oline number over from Open Phone
  • Jan 23, 2024 11:40 PM UTC
  • 2 replies
  • 111 views
I currently have an online number from Open Phone. Is it possible to port it over?
Sophia
  • Jan 23, 2024 11:43 PM UTC
  • Jan 24, 2024 12:08 AM UTC
You can check here to see if the number is eligible to be ported over.  If it says no, then you will need to follow the link Sophia sent above, but it is no guarantee that it will work
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
