iphone 12 on 3G network
  • Dec 21, 2021 5:15 PM UTC
  • 9 replies
  • 923 views
Melissa Bijker
Just purchased my phone and it is showing 3G network.  It’s supposed to be 5g.
Best answer by rikkster
Yes I have.  That was the first thing the rep at the store had me do
Another option is to reset your iPhone’s network settings. You can wait for the tech if it’s easier to follow instructions by phone, or use this guide for reference.
To reset your iPhone’s network settings; turn iCloud Keychain off by going to Settings and tap your Apple ID (where your name, Apple ID, iCloud, Media & Purchase appear). Tap iCloud, then look for and tap on Keychain, toggle iCloud Keychain off.
Turning off iCloud Keychain preserves Wi-Fi passwords, Safari usernames, passwords and credit card info.
Next, go to Settings > General - scroll down to Transfer or Reset iPhone. Tap Reset, then select Reset Network Settings - enter your passcode and wait for your iPhone to reboot). Remember to turn iCloud Keychain back on when your iPhone has rebooted.
This procedure restores cellular, Wi-Fi and Bluetooth to their factory default values and does not erase anything from your phone. You may have to re-pair Bluetooth devices (if applicable) and VPN settings will have to be reconfigured (if applicable). Verify that your iPhone stays on LTE.
  • Dec 21, 2021 5:17 PM UTC
Koodo sells 5G capable phones but does not have a 5G network. I find the LTE network to be fast enough for years to come personally. As for why it says 3G, did you confirm in network settings thst it's set to connect to all network types? Is data enabled? Does anyone else in your area show as 3G?
Melissa Bijker
Thanks for the reply.  I’m the only one whose phone is showing 3G.  Actually jumping from LTE to 3G.  Data is enabled and I believe it’s connected to all network types.  Showed LTE and 3G only.
  • Dec 21, 2021 5:53 PM UTC
Check the map coverage to see if you’re in a LTE area.
Melissa Bijker
I am in an LTE area.  I’ve had no issues with my Androids.  I just switched to iPhone yesterday.  I’m sure (or hoping) this is no big deal but would like to get it resolved.  I finally was able to set up a callback from support.  Fingers crossed
  • Dec 21, 2021 6:40 PM UTC
Have you tried restarting your iPhone?
Powering an iPhone off and on sometimes resolves network glitches.
Melissa Bijker
  • Dec 21, 2021 7:04 PM UTC
Melissa Bijker
THANK YOU so much!!! It worked!
  • Dec 21, 2021 8:22 PM UTC
That’s awesome and you’re welcome!!!
