International call not going through.
  • Aug 16, 2022 12:32 PM UTC
  • 554 views
I am trying to make an international call to South Africa. It rings once and then i get an automated message saying that the call did not go through. I see i do have international calling as an add on. Please advise.
Regards
Boa_Guy Koodo
Hi there @Hencolinde ,   The message you heard, was it something like this “ The number you dialed is within a number range that has been blocked for security reasons. If you require further assistance, please contact TELUS/Koodo at 611, or contact your long distance provider.”
  • Aug 17, 2022 8:13 PM UTC
Boa_Guy Koodo - No the message was just “Your call did not go through. This is an automated message” and then it repeats itself in French as well.
Boa_Guy Koodo
Hey, @Hencolinde  We suggest checking if you are dialing correctly, just in case.
Example: You should not dial 0 after UK country code (44) if you are calling UK from Canada
011-44-0 + XXXXX XXXXX is incorrect as valid calling pattern from Canada to UK is 011-44 + XXXXX XXXXX (10 digits)
its the same for South Africa
Hope this helps. :)
  • Aug 25, 2022 2:42 PM UTC
Hi @Boa_Guy Koodo
I rechecked my number but no success yet.
This is the number i am trying to dial in South Africa - 0860 123 003
I have dialed - +27 0860 123 003, +27860 123 003, 01127 0860 123 003 & 01127 860 123 003.
I get the following message - “6uc2, the number you have reached is not in service” or “we’re sorry the call did not go through”
Please advise.
Sophia
  • Aug 25, 2022 3:07 PM UTC
Can you try if your call is getting through with a service like MyTello just to rule out any errors? They give some free credit so it shouldn't cost anything to try.
