I don't see my full amount of data
  • Aug 5, 2022 11:21 PM UTC
  • 2 replies
  • 197 views
Hello,
I very recently got the 15GB data plan, and this is my first time having data. When I checked the usage tab to see if I can start using the data, it says 0/6.5GB. My bill cycle is July 11-August 10, and I switched my plan July 30. Is it not showing the full 15GB because it’s still between the cycles/It will show the full amount by August 11? If so, am I still ok to use the 6.5GB of data?
Thanks in advance!
Best answer by Sophia
Correct :) It’s called proration. You can find more about it here: https://www.koodomobile.com/en/help/proration
Sophia
  • Aug 5, 2022 11:35 PM UTC
  • Aug 5, 2022 11:49 PM UTC
Ok, that makes sense. Thank you :)
