How can I find out what is using my Data during the night
  • Jul 28, 2024 7:12 PM UTC
  • 262 views
What little data I get each month gets used up by something during the night. I so very seldom use my data.
Best answer by Dennis
Wifi assist - a feature that allows the use of cellular  data to help when wifi is not strong
  • Jul 28, 2024 7:34 PM UTC
Hi @emarr
We recommend checking this article to find out more about how you can reduce data usage: https://www.koodomobile.com/en/help/keeping-track-your-data-usage
  • Jul 28, 2024 9:14 PM UTC
Are you connected to wifi at home, make sure wifi assist (uses data to help when wifi is not strong) is turned off.
  • Rockstar
  • Jul 28, 2024 9:29 PM UTC
Yes I’m connected to Wi-Fi at home. What is Wi-Fi assist?
  • Jul 28, 2024 9:44 PM UTC
  • Rockstar
  • Jul 28, 2024 9:49 PM UTC
Thank you, found out how to turn it off.
