facetime
  • Jan 25, 2024 6:47 PM UTC
  • 1 reply
  • 90 views
Hi i have a question
if i do FaceTime call , does it show in the app who i called or the number?
or how much time i was on a FaceTime call or not .
i want to know what are the privacy terms of FaceTime usage in koodo app.
1 reply
  • Jan 25, 2024 9:55 PM UTC
When you make a FaceTime call, Koodo (Koodo doesn’t have an app) will not display the specific details of the call, such as the person's name or number you called, nor will it show the duration of the FaceTime call.
FaceTime calls are typically managed by your device's operating system, and the specifics of the call, like who you called and how long the call lasted, are not directly visible within Koodo Self Serve.
