esim, should I use that or just the US roam fee, does esim have data
Hi
A physical sim card or an eSim, both use mobile data from you plan.
if you use mobile data while roaming, the roaming fees will trigger.
For US, you can consider the travel pass if you travel for 7 days or more, or the daily fee if you travel for a very short period.
More info about Easy Roam and Easy Roam travel pass can be found below:
https://www.koodomobile.com/en/help/easy-roam
https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
This article explains how to prevent unwanted roaming charges:
Did you get a US travelling esim?
Where is your esim from?
How do you access your Koodo service, from the esim or a physical sim?
Login to the community
