craziness
  • March 19, 2026
  • 25 replies
  • 104 views
I need tech-support. My phone isn’t working and nobody can get a hold of me because it goes straight to voicemail.
  • March 19, 2026
Are you able to make outgoing calls?
Was your phone working prevously?  Are you new to Koodo?
  • Advisor
  • March 20, 2026
Yes I can make out going calls and some incoming if they call me twice because it goes straight to voicemail mail then they call back them the call comes through
  • March 20, 2026
Can you check if you set the phone in "Do not disturb mode"? Or any personal mode? Sometimes, that was the cause of the 1st call block while leting the 2nd call goes through
  • Advisor
  • March 20, 2026
I’ve checked all these things. I’ve even checked call forwarding I’ve turned my phone on. I’ve turned it off.
  • March 20, 2026
Are you able to remove your SIM card and put it back into your phone? Does it resolve the issue? What about inserting your SIM card into another device?
  • Advisor
  • March 20, 2026
No sim
  • March 20, 2026
Have you tried resetting the network settings on your phone?
  • Advisor
  • March 20, 2026
? Why? I’m with Koodo since January it’s been fine up until now
  • March 20, 2026
What phone do you have?
If it takes 2 calls for calls to come through, then it sounds like DND mode is enabled.
https://discussions.apple.com/thread/254881214
Are you able to narrow down if this is always the case?
🤦What do you mean why?
This is why….
  • Advisor
  • March 20, 2026
Nope. That’s not it either
  • Advisor
  • March 20, 2026
No, it’s not always the case and it’s only with certain phone numbers. I’ve taken them off the spam list if they were on it in the past I’ve also with their texts check that out and remove them if it wasn’t spam. I’ve done everything that I know to see if there’s anything blocking them from calling me and it doesn’t appear to be the case.
  • Advisor
  • March 20, 2026
That’s why I would like a customer care representative to call me because they can’t even get through. They aren’t even on the spam list. It goes straight to voicemail with them and I can’t interrupt or intercept the phone call if they do or when they do. Then I get kicked back into having to go through this all over again and set up a scheduled phone call. It’s frustrating that’s why I call it craziness and a crazy loop.
  • March 20, 2026
Can you narrow down what category of certain numbers?  Like are they numbers that you have saved in your contacts?
Have you made any recent changes?
Understanding the issue, no one here is asking you to request a callback when you are unable to receive calls.
Do you have numbers blocked on your phone?  Where it allows only certain numbers?
  • Advisor
  • March 20, 2026
They can text me if they can have a form or it’s a customer care representative through a text on Kudo self serve but no, it’s some crazy robotic AI machine that says we will have someone call you. That’s not convenient for everyone.
  • Advisor
  • March 20, 2026
I’ve been there bro checked it all out. It’s not my phone. Koodo. Koodo needs to straighten things out at there end.
  • Advisor
  • March 20, 2026
Kudo is not blocked
  • March 20, 2026
Yes I undestand.
But can you answer the following….
  • Advisor
  • March 20, 2026
Yes, there are numbers that I have saved in my contacts. These are important numbers. They can’t get through to me even my own mother had to do this. Call me twice in order to get through first time. It went straight to voicemail. The second time it went through. And yes, it is with the people that I know and people that are on my phone contact list. I’ve went through my contact list to make sure that I haven’t silenced them. I’m not an airplane mode. It’s just a frustrating problem.
  • March 20, 2026
Thank you for answering 1 of the 3 questions.
I will wait until you answer the other 2 questions
  • Advisor
  • March 20, 2026
I have not made any changes to my original set up with Kudo two months ago. This is a new issue.
  • Advisor
  • March 20, 2026
iPhone 15Pro Max
  • March 20, 2026
If you already reset your network settings and it does not work, how about removing those specific numbers from your contact list and adding them back again on your phone? This is the other method that may resolve your issue.
  • Advisor
  • March 20, 2026
For what purpose?
  • March 20, 2026
We are trying to help you, but you are not even willing to try it out.
If you do not want any further assistance in the Community and need someone at a physical store, you may want to set up a reservation at the Genius Bar.
  • March 20, 2026
It would simpler if you have a physical sim to see if the issue follows the device or the sim.
Right now from your description it sounds more like a device issue and not a Koodo backend issue with your account.
