Conversion from SIM to eSIM did not take
  • Jul 26, 2023 6:34 PM UTC
  • 9 replies
  • 856 views
I followed the instructions at https://www.koodomobile.com/en/help/esim-and-esim-vouchers. Everything looked like it’s suppose to, but in the end I ended up with eSIM that’s showing “Unknown” and “Unknown number”, and no connection whatsoever. My original SIM card is still working (and showing correct phone number). I tried to reboot, take out original SIM, etc. No luck. eSIM is still not providing any connection.
Best answer by Dennis
Did you complete a sim swap in your self serve?
  • Jul 26, 2023 7:11 PM UTC
So you bought an esim from a store or you were converting  the existing sim into an esim?
From your description, the trasnfer wasn't successful, have you tried to redo it?
  • Organizer
  • Jul 26, 2023 7:14 PM UTC
Got eSIM in the store. When trying again I get “This eSIM has already been used” message. Phone is Samsung Galaxy S23 Ultra.
  • Jul 26, 2023 7:21 PM UTC
Can you remove the physical sim out of the phone and reset network settings to see if it can help?
  • Jul 26, 2023 9:46 PM UTC
  • Organizer
  • Jul 26, 2023 10:03 PM UTC
Removing SIM + network reset did not help.
SIM swap is probably on the track, but it doesn’t look like feature is working. This is what I have on the screen after 5 minutes of waiting.
Would SIM swap even work to eSIM, or does destination have to be SIM too?
  • Organizer
  • Jul 26, 2023 10:06 PM UTC
On second attempt SIM swap screen is now working, but it says
Heads up:
Don't insert your new SIM into your new phone until the SIM-change process is complete.
Since I already tried to register eSIM will this work at all, or am I going to deregister original SIM and be left without original SIM and new eSIM?
  • Jul 26, 2023 10:15 PM UTC
It should only deregister your original sim if it can register your new sim.
Your phone does show your esim as available to use, just unknown and unkown number right?
  • Organizer
  • Jul 26, 2023 10:16 PM UTC
That is correct. It shows eSIM and “unknown” and “unknown number” next to it.
  • Organizer
  • Jul 26, 2023 10:31 PM UTC
SIM to eSIM swap in self serve successful! Thank you.
