Changing Rate Plans
  • November 24, 2023
  • 296 views
Hi, I currently have a $65 plan with a monthly $20 discount. If I change to the upgraded $65 plan with 5G 120 GB data, do I get to keep my discount so I pay the same amount monthly?
Best answer by Bernard Koodo
@wisegreatz As long as you stay on $65 or above plan you will be fine.
  • November 24, 2023
What type of credit was it? If it is a black Friday credit last year and you simply change your rateplan, that credit likely stays
  • November 24, 2023
It was black friday
Bernard Koodo
  • November 24, 2023
  • November 24, 2023
Hi @Bernard Koodo , I just changed my plan. Can you confirm for me That the discounts will remain?
  • November 24, 2023
Looking to get confirmation, currently on the $65 plan from last year, would like to switch to the CAN-US 120GB $65 plan, will my credits stick around after the change on both lines
  • November 24, 2023
@nessa-L Yes, the credits will stay as long as the new plan is of the same cost or higher.
