Changing from Koodo postpaid to prepaid plan - unable to port my number
  • Sep 11, 2022 2:04 AM UTC
  • 4 replies
  • 1053 views
MVantriet
I currently have a Koodo postpaid plan and am going to switch to a prepaid plan. I have purchased my Koodo prepaid SIM card and am going through the activation process. I wish to keep my current number. When I get to the field where it requests my current provider, I CANNOT CHOOSE KOODO (it is not shown as one of the options) so I cannot go any further in the process.
Am I missing something? How do I get past this field to complete my prepaid activation? Thank you.
  • Sep 11, 2022 2:40 AM UTC
You could try activating with a random number and then after registering in self serve on your prepaid account, try move your number to port.
MVantriet
  • Coach
  • Sep 11, 2022 2:58 AM UTC
Thank you - that sounds like it might work - I just don’t want to risk being without my number. Can someone from Koodo confirm that this is the way to do it?
  • Member
  • Oct 15, 2022 4:25 PM UTC
Did it end up working for you?
Sophia
  • Oct 15, 2022 5:00 PM UTC
@Dave Ender not sure if OP will respond, but I can vouch that the method Goran mentioned will definitely work. It's the safest way to port your number.
