cancellation
  • Sep 13, 2021 8:32 PM UTC
  • 7 replies
  • 438 views
How can I cancel my Koodo account in China, where I cannot make a call or use facebook?
Best answer by Nezgar
If fongo mobile doesnt work (who knows with the "great firewall" ) - the TextNow app is another worthy alternative, with free calling to Canada / USA. Hopefully one of them work for you.
Another thought to consider... If you like your number and want to keep it for future use when you return to Canada, you could port it out to a parking service like NumberBarn or voip service like Voip.MS... though that could be a complicated if you cant receive the port out verification text in China..
  • Sep 13, 2021 8:34 PM UTC
If you are unable / unwilling to use a VPN to use FB/Twitter, or can't borrow someone's vpn to do so, I can flag a Rep to speak to you privately about some other option.
  • Sep 13, 2021 8:44 PM UTC
Hi thanks very much for your reply. Is there any other option to do that? Can I send an email? I do not have vpn and have no idea how to use that.
  • Sep 14, 2021 1:10 AM UTC
No email. But a rep can private message you here.
Let me flag a rep for you
  • Sep 14, 2021 1:15 AM UTC
Which device are you using? Can you download any apps? If so, you can get an app that can make or receive calls, such as Fongo, and schedule a callback to that number instead.
  • Sep 14, 2021 2:23 AM UTC
I am using Android OnePlus. I am going to try Fongo. Thanks a lot.
Nezgar
  • Hero
  • Sep 14, 2021 2:49 AM UTC
  • Sep 14, 2021 8:54 AM UTC
Thanks a lot for your detailed suggestion.
