birth date record is incorrect
  • Jan 21, 2023 10:58 PM UTC
  • 4 replies
  • 238 views
I spoke to a rep and was asked for my pin. I gave it to her and was told it was incorrect. Was then asked for my date of birth and that was wrong. Where do I find this info so I can correct the info
  • Jan 21, 2023 11:40 PM UTC
If you are post paid a credit would have been performed. So the birth date should be correct.
If for some reason the birth date is incorrect then I would have asked the rep for another line of questions to confirm your identity.
Was the name and phone number on the account at least correct?
  • Advocate
  • Jan 21, 2023 11:44 PM UTC
Was not asked for anything more. Just told to go to a koodo store and they will correct it. Must be somewhere on record
  • Jan 22, 2023 5:32 PM UTC
I don't think you can correct this info yourself without going in-store with proper ID.
  • Jan 22, 2023 8:42 PM UTC
So the answer to your question is to just go to a koodo store with your ID to correct the error.
