aiplane mode
  • February 11, 2026
  • 3 replies
  • 27 views
In order to receive a scheduled call back with an agent, does my phone have to be taken off airplane mode?
  • February 11, 2026
Hi ​@Mhudson
Yes, you would need to have the phone connected to the network, so you can receive the call back!
If you are roaming, you won’t be charged for the call received from the Koodo rep. Just make sure you have data turned off, and don’t make other calls or send texts.
  • February 11, 2026
If you do not have Wi-Fi calling enabled, then yes that is correct. Airplane mode disconnects you from the cell towers, so if you’re not using Wi-Fi calling for the call then you would need to turn it off.
Edit: whoops seems Flo got to it at the same time. 😅
  • February 11, 2026
What are you requesting a callback for?
Maybe we can help you here or direct you toward the best channel to answer your questions.
