What comes with Samsung S23 phone?
  • Sep 10, 2023 8:03 PM UTC
  • 360 views
What comes in the box for a new Samsung S 23 phone? Wondering if the charging cord is included.
Best answer by Dinh
The box should have the phone and a charging/data connection cable.
  • Sep 10, 2023 11:15 PM UTC
  • Advisor
  • Sep 11, 2023 12:31 AM UTC
Thank you.
  • Advisor
  • Sep 20, 2023 3:27 PM UTC
Update!
New phone does NOT come with charging cable 😡.
What a dissapointment, no longer do manufacturers give head phones, charing blocks nor cables. THAT used to be value for money.
Allan M
  • Sep 20, 2023 6:27 PM UTC
It does, it’s a little hidden though.
In the top part of the box, if you look inside, there’s a little black cardboard piece that has a little hole to remove it. The cord is hidden inside that part.
You can see it in this video around the 1:30 mark:
  • Sep 20, 2023 6:31 PM UTC
If you go to the Koodo website page for the Galaxy S23, scroll down to the bottom and click on “Technical Details,” it’ll tell you what’s in the box. It says charger sold separately. I guess this includes the usb cable in “charger.” The headphones haven’t been included for a number of years now.
It’s quite common now for most OEMs. It’s too bad they didn’t decrease the cost for not including them anymore. Upside is that decent cables and chargers aren’t expensive anymore.
  • Advisor
  • Sep 20, 2023 9:22 PM UTC
@Dinh  I apologize,  I was wrong. It does come with a cable. Thank you @Goran for leading  me to its location.
I'm not confident in purchasing off brand charging equipment. Have it in my head that there is a chance that it could harm the phone.
