If I buy a phone and pay monthly payments of 24 months and it says $8 a month what is the best least amount plan would I get.? I pay $40. A month and my phone is paid off. I'm looking to upgrade or get the same, my phone works but its got a few cracks and it goes wonky at times. I just can't figure out the total that I'll be paying and I'm worried it will be so much higher than $40 a month. I'm a disabled person with a very low income.
Page 1 / 1
Go on to the Koodo site, login, add a phone to your cart, and then one of the next steps should be for you to select a plan and from there you can see which ones would be available for you to choose from.
Login to the community
or
