Transfering my data after a phone replacement.
  • Sep 28, 2022 3:26 PM UTC
  • 3 replies
  • 706 views
I am getting a replacement phone delivered. I am wondering if the Rep at Hamilton's Center Mall can transfer my data and if so will it cost me another $50.00?
Best answer by Boa_Guy Koodo
Hi there! Here is a helpful article to help with the process.
Hope this helps.
Boa_Guy Koodo
  • Koodo Alumni
  • Sep 28, 2022 3:55 PM UTC
Hope this helps.
  • Sep 28, 2022 6:30 PM UTC
Sorry but it doesn’t help. I bought a Motorola android phone on the 12th of this month. On the 23rd, it got knocked to the floor (hence the replacement). Just need to know if I will be charged another $50.00 to set it up at a Koodo outlet.
  • Sep 29, 2022 5:39 AM UTC
If you upgrade a new phone at a store, there would be a $50 connection fee.
