Answer
Phone Waitlist
  • November 25, 2025
  • 3 replies
  • 59 views
Hi, I’m just wondering if there’s a phone waitlist option for purchasing phones? The Iphone 14 is still showing up on the shop page, but they’re all out of stock.
Best answer by Oliver C
No, Koodo do not currently offer a waitlist option for purchasing phones online, it is a first come first serve system so that it is equally fair. You will have to keep checking the website.
Just note that the iPhone 14 may not come back in stock as it has been discontinued by apple when the 17 line up was released, so it may only be while supplies last.
  • November 25, 2025
  • November 25, 2025
If you’re open to other options, you could try checking Koodo’s Certified Pre-owned section or look at the deals page; sometimes older iPhones pop up there when they get new stock or trade-ins.
  • November 25, 2025
Unfortunately, the CPO devices are only available on the Koodo page, so you may be out of luck.
However, you can consider checking out Mobile Klinik, a partner company, for a refurbished iPhone 14 with free shipping and one-year warranty. It is currently low in stock, so you may want to either head to your nearest location or order online as soon as you can. https://shop.mobileklinik.ca/products/apple-iphone-14
