I want my problem solved.
My phone was stolen when I tried to have it repaired and they asked me for 210 dollars. I pay 16 dollars every month and I keep it.
I have device care
Did this help you find an answer to your question?
  • 1605 replies
  • April 2, 2025
So Device Care Complete, like any insurance coverage, grants you the ability for a device to be replaced or repaired but for a deductible cost depending on the damage.
If the device is stolen or lost, you have to pay the maximum deductible for a replacement device and the amount will be put on your next bill. More information on this can be found in the link below.
https://www.koodomobile.com/en/help/device-care-complete
  • 13585 replies
  • April 3, 2025
While I typically do not recommend extended warranties, as statistically you come out ahead handling repairs yourself and using a case/screen protector, times when the phone is stolen or damaged beyond economic repair could make it worth it. It has been normal for basically all insuurance and extended warranty options to have a deductible for a device replacement for many years now. It’s something you’ve gotta crunch the numbers on to decide ifit’s worth it or not for you.
