Unlimited Incoming calls on $15 base plan
  • Sep 6, 2022 4:38 PM UTC
  • 4 replies
  • 459 views
On the new $15 base plan, do the “unlimited incoming calls” include calls from the US?
Best answer by Goran
The 100 minutes are for outgoing calls to Canadian numbers. It’s unlimited incoming, which is like a separate thing. They don’t count towards your 100 minutes. It might be helpful to refer t them as 100 outgoing minutes but the nomenclature is just 100 Canada wide minutes + unlimited incoming minutes.
Boa_Guy Koodo
Hi there, if you are in Canada, you can receive a call from anyone, anywhere. It's always the caller that initiates the long distance that pays the fees.
  • Sep 6, 2022 6:09 PM UTC
thank you for your quick answer. Do these incoming calls count toward my minutes?
  • Sep 6, 2022 6:11 PM UTC
  • Sep 6, 2022 6:29 PM UTC
Thank you so much.
