Prepaid plans that have unlimited canada-wide calling: Some of the prepaid plans descriptions on the koodo pre-paid webpage specify they include unlimited incoming calls, but most do not (just saying, unlimited canada-wide calling). That some specify incoming and others do not makes it unclear as to what is actually included under the ‘unlimited canada-wide calling’ banner.
Do ALL plans that say they include unlimited canada-wide calling actually, definitely for sure, include both outgoing and incoming calls for free? I want to change plans from an older base plan that did not include any minutes, to the cheapest one which says it includes unlimited canada-wide calling, but need to be sure it actually includes both incoming and outgoing minutes.
Also, if i change, will my automatic top-up remain in place and active … and, do i have to add funds for the new plan, or will it just charge my registered card (and apply the auto top-up) as usual on the date the new plan comes into effect?
Prepaid unlimited canada-wide calling - outgoing and incoming?
Best answer by Robert T
Here's the thing: Yes, if your Koodo prepaid plan says “unlimited Canada-wide calling,” that means you get unlimited free outgoing and incoming calls anywhere in Canada—no need to worry about minutes for either as long as you’re in Canada. You don’t pay for incoming calls on these plans either.
When you change your plan, your auto top-up stays active. You don’t need to add extra funds if your balance or auto top-up covers the new plan’s cost; it’ll just charge your saved card or use your balance as usual when your plan renews.
More info: https://www.koodomobile.com/en/help/prepaid-base-plans
Login to the community
