prepaid plan without SIN
  • Jan 17, 2021 4:29 PM UTC
  • 4 replies
  • 553 views
Hi, Please help me with the following questions.
  1. Can I buy a prepaid SIM without a Sin number (I am New)
  2. Can I change my Payment method in the future
  3. In the website there is a section saying a connection fee of 45, what is that? (I thought it was free)
  4. Once SIM received, how long does it take to get it activated?
  5. How can I check if my phone is compatible with the network or not. If it is compatible, it should be working without a  glitch, right? I mean, do I have to look for anything else to see if it will be working or not?
  6. How International calls are charged when I am on a prepaid plan ‘$40 per 30 days’
Sorry for throwing out too many questions. Thank You
Best answer by Goran
  1. Yes you can
  2. Yes
  3. If you get your line activated in store you are charged 45 dollars. It's free online. You can get a prepaid Sim anywhere and activate online for free
  4. As soon as you do it online for prepaid
  5. If it has quadband 3G and at least band 4 lte plus others then it should be compatible.Koodo does also have a comparability tool to put your phones Imei into: https://www.koodomobile.com/en/help/finding-your-imei
  6. Here is the list of countries you can call on prepaid: https://www.koodomobile.com/en/help/long-distance-travel-and-roaming-prepaid
I suggest if you want to make international calls that you use calling cards or VoIP options instead.
  • Jan 17, 2021 4:34 PM UTC
  1. Yes you can
  2. Yes
  • Jan 17, 2021 4:49 PM UTC
Thank You very much @Goran . that helps a lot. I have one more question- what is tab plus/mid plan? do i need to get a device from koodo to get these plan working. are those post paid plan?
Sophia
  • Jan 17, 2021 7:30 PM UTC
You asked about prepaid before, so the tab doesn’t apply there. You can use any compatible phone without having to worry about that :)
For postpaid plans, the Tab means that you can pick a phone with your plan, and then it is paid over the next two years instead of all at once. The bigger the tab, the less you pay up front and the more you pay per month.
  • Jan 17, 2021 8:07 PM UTC
@Sophia Thank you very much. Now I understand this now.
