Oops!, Wrong Prepaid Booster Add-on
  • Apr 4, 2022 7:01 PM UTC
  • 2 replies
  • 173 views
In error, I purchased the wrong Booster Add-on. Can I get it credited/removed so that I may purchase the correct one?
I meant to purchase US Data (500MB, $20), but purchase a standard Data Booster by mistake (1GB, $30). It was just purchased minutes ago, and hasn't been used.
Thanks
Sophia
  • Apr 4, 2022 8:24 PM UTC
You can schedule a callback from the digital assistant and ask if they can change your booster to the correct one for you… since you haven’t used it I expect no troubles :)
  • Apr 4, 2022 8:41 PM UTC
I've scheduled a callback.
Thank you!
