New Phone, Same Prepaid Plan?
  • May 22, 2021 10:09 PM UTC
  • 2 replies
  • 617 views
I’m looking to get a new phone as my current one is on its last legs. I have an unlocked phone and purchased a prepaid basic plan for it 2 or so years ago.
I was wondering if it is possible to purchase a new phone from koodo, such as an iPhone XR with the monthly payment plan without a new usage plan, but instead put my current Koodo SIM card into the new phone?
Thanks!
Best answer by Dinh
If you change your mind and  you would like to change your plan from a prepaid plan into a postpaid plan (with the new phone XR), you could follow this guide https://www.koodomobile.com/en/help/moving-prepaid-postpaid-monthly-service
Basically, you would have to register a new postpaid account and port your prepaid number into the new postpaid service.
People often choose to  buy phone from carriers because they offered extra discount on phone and plan.  It might be a better deal over the 2 year period.
Sophia
  • May 22, 2021 10:31 PM UTC
First, yes, you can use any phone you want with prepaid - I’m currently using the Note 20 Ultra. So that’s not a problem.
However, Koodo won’t allow you to buy just any phone from them without a plan - so you may need to look elsewhere and buy a phone outright. Apple and Google are usually the best stores to buy phones outright, depending on whether you’re into iPhone or Android :)
  • May 23, 2021 2:32 AM UTC
