Does connection fee apply for prepaid SIMs?
  • November 10, 2023
  • 2 replies
  • 385 views
Hello,
If I buy a prepaid Koodo SIM in-store, does the $60 connection fee still apply or is this only for postpaid (monthly) accounts?
Also, is there any way to use an E-SIM without first having a physical SIM (for new prepaid customers)?
Thanks
Best answer by Flo Koodo
Hi @cinergi
Connection fee wouldn’t apply for prepaid activations, you would just pay the cost of the sim card and then activate online using the steps here: https://www.koodomobile.com/en/help/activating-your-prepaid-phone
At the moment, prepaid activations on eSim cards are not possible.
  • November 10, 2023
Hi @cinergi
  • November 10, 2023
Thank you for clarifying!
